DQMH Consortium Toolkits Feature Requests
Olivier-JOURDAN
Move Stop Module.vi next to Start Module.vi in the library hierarchy
Status: New
Accepted for a future DQMH release
IMHO, it would make more sense to have the Stop Module request at the same level than Start and Sync functions.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
5 Comments
Jens_S
Well I have to say that I disagree with this. The Start Module VI is not a DQMH request at all so it's separated from the other build in request like Stop Module. At first I also found this a bit confusing but it makes sense if you think about it from a DQHM point of view.
Olivier-JOURDAN
Active Participant
@Jens_S, the stop module is a request, yes, but the code doesn't look like all the other requests.
Moreover, I'm not sure the hierarchy needs to follow the nature of the code. For me, that's more a kind of palette organization. In this way, it makes sense for me to have the start and the stop at the same level.
Olivier Jourdan
mbaudot
Active Participant
Status changed to: Released
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
Olivier-JOURDAN
Active Participant
Status changed to: Development Started
DQMH version target not defined
Olivier Jourdan
mbaudot
Active Participant
Status changed to: New
