DQMH Consortium Toolkits Feature Requests
Darren
Optionally "optimize" new Cloneable module to be called as Singleton
Status: Declined
Too risky when the time comes to use it as a cloneable.
I sometimes create Cloneable modules that I intend on usually calling as singletons. For these modules, I often manually update each request to have its Module ID input recommended (instead of required) and the Module ID default value of 0 (instead of -1). I also make the 'call as singleton' input on Start Module.vi have a default value of TRUE (instead of FALSE).
I'd like for there to be an option when creating a new cloneable module that says something like "optimize for calling as singleton" that would create the default requests as described above, and would also be tagged in some way so when I add new requests they will be created as described above.
(idea originally posted here)
1 Comment
Olivier-JOURDAN
Active Participant
Status changed to: Declined
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
