Using DQMH 7.0.1.1316 (currently the latest version), the error message generated inside the Default case of the Message Handling Loop is "The invalid message string "%s" was received in the Message Handling Loop for module "%s"."
"The invalid message string "%s" was received in the Message Handling Loop of module "%s"." might be a small improvement.
Accepted.
