Actor framework vs DQMH
But if the only event that can occur among consecutives steps (each with its own event/message) is a stop and abort, would it be OK to self messaging?
Or if the system is OK with other messages that can be handled among steps, I guess it's ok to self-message the MHL
Message 11 of 21
(4,237 Views)
@joerg.hampel  ha scritto:
@FabiolaDelaCueva wrote:
Check out tip 4 from this blog post http://delacor.com/tips-and-tricks-for-a-successful-dqmh-based-project/
It talks about how to create state machines inside a Message Handling Loop case.
I would prefer a helper loop to a state machine inside the MHL.
I dont understand from your blog post how to do that. Fork the event refnum? how do you place the node "DQMH_REG_HELPER" ? where does it come from?
EDIT : ok solved
Message 12 of 21
(4,231 Views)
Why the disk structure of DQMH is flat?
would it be better to create some subfolders in the script?
So that I will put my events inside my folder, to distinguish from "built in" events/VIs?
Message 13 of 21
(4,207 Views)
Use the Project Explorer for project organization. It's much easier to make project organization changes in the Project Explorer than on disk.
Message 14 of 21
(4,200 Views)
They each have their use.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 15 of 21
(4,188 Views)
For a detailed explanation of why we should not fork the Event Registration wire, check out this post:
https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Registering-to-broadcast-events-from-many-modu...
The general rule should be a Register for Events Node for each Event structure (with dynamic event terminals visible) handling events.
Message 16 of 21
(4,176 Views)
We do exactly that and store all manually created VIs in subfolders. The default is "SubVIs", but that varies depending on the module.
Those folders are also reflected in the virtual folder structure inside the .lvlib.
Message 17 of 21
(4,155 Views)
It's also quite easy to move files around on disk in the Files view of the project explorer windows (actually something I learned from Fab!)
Message 18 of 21
(4,151 Views)
You've made my day, I didn't know we could do that!
I never even suspected NI could add such a neat feature 😮
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 19 of 21
(4,143 Views)
wtf really LOL
But you can't delete from that view... you can only explore... or move (also with drag/drop into the file system tree)
Message 20 of 21
(4,088 Views)
