Clouse TDMS File in Logger
Hello experts,
I am now getting to know the CML Delacor project and have the following questions:
Command start creates a TDMS file in Logger.vi in the "Initialize File" case. Stop logging function stops the measurement and logging. If I do not close this CML UI module but start logging again, this creates a new TDMS file and the first TDMS file stays open until I close the CML UI module. After that, both files are properly closed and no data is lost.
My questions are where is the data from the first start saved? Do I have to close the CML UI file after each measurement in order to close the TDMS file?
Thanks a lot
(2,871 Views)
Hello experts,
Does anyone use the project CML Delacor? There is a solution to my question yesterday: another Close file.vi comes in the Logging module in the case "Stop Logging". Now the command "Stop Logging" also closes the TDMS file and the module CML UI continues to run on repeated measurement. At each new measurement the measurement data come into individual TDMS files without closing the module CML UI. See the picture below.
Alex
(2,831 Views)
Hello Alex, I used the CML project back in time when I was learning DQMH. It demonstrates many good practices.
That being said, I'm not using it as a starting point for my applications.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(2,669 Views)
Hello Olivier,
thanks for the answer. I'm just learning DQMH and that's why I use CML project. What can I use for Start Point with DQMH for a project?
Alex Sigalov
(2,541 Views)
Once you are comfortable with DQMH, I can see different options to have a starting point project:
- Create your own template project based on the CML project (you can also glance at the other project provided with DQMH named Delacor QMH).
- you can also give a try to the layout manager provided by Hampel Software Engineering and also the MGI Panel Manager from MGI.
From my own experience, the best thing to have is a project you can start from without removing anything. It needs to contain what you need for all your apps.
Olivier Jourdan
(2,534 Views)
Alex, take a look at our Windows Application Template:
https://dokuwiki.hampel-soft.com/code/dqmh/hse-application-template
To us (and a few more people), it's exactly that: A starting point for new projects, a generic shell that is then filled with project-specific contents.
(2,530 Views)
Hello Olivier, hello Joerg,
thank you very much for your feedback.
Alex Sigalov
(2,492 Views)
