DQMH Main in the UI Execution System
I rarely change the "Preffered Execution System" of a VI but I just got an error in my main that may require it.  I want to see peoples thoughts on that.
On my main I am adding an ActiveX control to load a PDF.  When I load the PDF I get error: "Error 3006 occurred at Automation Interface can only be used in the User Interface Execution System."
So... I can make the main in the UI, but I am not sure that is the best method.  I guess I could make a subVI and use a subpanel.
Thoughts?
(4,900 Views)
All bets are off with ActiveX and .NET. I had a similar situation a while back where the main VI of my (non-DQMH) app just wouldn't work at all unless I ran the VI in the UI thread. It was doing a bunch of .NET stuff.
(4,897 Views)
Is there any specific "danger" to running the DQMH in the UI?  It has been awhile since I dove into the pros and cons of execution systems, but I do remember UI being one I didn't generally play with, thought I thought property nodes where in the UI thread....
(4,895 Views)
Accepted by Evan
I don't think there's any danger in running the DQMH main VI in the UI thread.
(4,893 Views)
