DQMH Consortium Toolkits Discussions
DQMH Post Scripting
Greetings,
With the more later release of DQMH a set of scripting tools have been released to be utilized after completion of existing DQMH script operations. This is a great addition, but I'm not sure how to utilize it.
For example, if I create a new DQMH Event with the standard Tools > DQMH Consortium >DQMH > Create New Event, there are changes that I have to make to the generated code each time this tool runs to work correctly with my projects. How do I go about using the post scripting tools to do this? Does anyone have an example of this?
Thank you for your help.
(995 Views)
The Post Scripting Plugins feature is documented here:
Scripting Plugins :: DQMH Consortium Docs
I know that Panther Dashboard installs some plugins, you can take a look at its source code for examples here.
(994 Views)
I've taken a look at the documentation, but it wasn't really clicking with me on how that helps me update my code.
I haven't heard of Panther Dashboard so I'll take a look at that as well. Thank you
(986 Views)
Accepted by pstestek
Hi @pstestek, Panther Dashboard adds some scripting plugins to refresh the tool after executing some of the DQMH Scripting tasks. If you want to see another example, take a  look at this:
https://www.vipm.io/package/pantherlab_lib_scripting_plugins_for_dqmh/
This VIPM package installs some VIS under LabVIEW Data. There will be a folder for each DQMH Task. When, for example add an event, a vi under the Add new DQMH Event folder will be executed to do some post scripting, you can take those as isolated examples.
(899 Views)
