Failing to rename Broadcasts?
I have a module which has couple events created as "broadcast" (so not, request, roundtrip or request and wait for reply). When I try renaming these events then I got the error message shown in the picture below.
I'm not sure if its just me or its there for others. Could somebody check?
(3,338 Views)
Accepted by 1984
The screenshot makes me wonder about a few things. Normally DQMH is using a reserved folder structure. If you created the event as "Broadcast", it shouldn't be named as "Request: something.vi". Renaming an event preserves the originally folder structure. The name of the event to be renamed should be called "Broadcast: something.vi". And you should never change the folder structure manually.
I checked renaming of broadcasts in my project and it worked well.
(3,334 Views)
Yeah you nailed it. I have moved these broadcasts cause I want them to be public. I'm pretty sure DQMH broadcasts should be private, but this particular supporting module is practically used to create named broadcasts easily to solve inter-VI communciation which at this point we can't solve otherwise due to time constraints.
The rest of our modules dont have such hacky things.
(3,326 Views)
For me this sounds like a practical application for roundtrips: requests are public and you can use them everywhere. So why you don't call a request which returns a broadcast (roundtrip)? So your broadcast doesn't need to be public (which makes no sense at all because the source of the broadcast is always inside a module which has something to tell).
(3,306 Views)
Because I dont need the DQMH module to run any code for these broadcasts, I'm mostly using the module to create named events quickly. As mentioned above, I know that it should not like this, but - for this project - it is.
(3,299 Views)
if you can explain what your use case is, there is probably a much easier and less hacky solution.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(3,192 Views)
I have bunch of asynchronous, non-dqmh modules which needs to send messages to each other. Due to architectural reasons switching them to DQMH modules is off the table, at least for now.
I have a dqmh module dedicated almost entirely to these broadcasts. The point is that I can very quickly generate events with dqmh. I could have a non-dqmh, maybe FGV based user event VI, but the dqmh autoscript does everything for me so I decided to take the easy road.
Remember:
"The one of you who is without sin, let him be the first to throw a stone at him."
(3,185 Views)
