Multiple events to single event case
I have legacy code I am considering refactoring to DQHM, at least for certain parts of it.
In my current implementation I have four separate graph panes on the front panel. Each of these have a number of identical dedicated graph control buttons.  In my event structure I select each of the four "instances"  in the same  event case, since I can then re-use the associated code by wiring the associated reference into the same vi (I don't use User Events).  Is it also possible/or advisable to register multiple events in the same event case in DQHM?  It works well for me in the current implementation.
(809 Views)
Are you referring to having a single frame of the DQMH Main VI event structure registered for multiple DQMH requests? I haven't seen that pattern before, and I'm concerned that it won't play nicely with certain scripting features like 'Remove Event'.
If I saw multiple requests configured for the same event frame, my first question would be why multiple requests were needed instead of just one.
(799 Views)
You could create a cloneable that contains a graph and buttons, and run it four times embedded in four sub panels.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(793 Views)
