Question about Rename DQMH Module
I've got a question regarding renaming - or rather moving - DQMH modules. Maybe that pertains more to lvlibs in general.
When trying to move a DQMH module to another folder, I first rename it via "Tools -> Delacor -> DQMH -> Rename DQMH Module...". The .lvlib file itself is then stored at the new location I specify.
What is the easiest / fasted way to also move the contained VIs of the .lvlib without breaking dependencies?
(4,047 Views)
Accepted by joerg.hampel
Hi Joerg,
One way is to right click on the library and rename it, in that process put it where it belongs (let's call that the <target folder>).
Then go to the files view on the project and drag all of the files from the <current folder>/ModuleA/  to <target folder>/ModuleA/*
Also, next time you create a DQMH module, you have the option of selecting which folder to put them on, the default is Libraries.
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(4,001 Views)
Thanks, Fab - this is pure genius!
Truth be told, I never really knew what the files view of the project window should be used for 🙂
(3,996 Views)
