Roast my Design
@AlexElb wrote:
For my files I just use Flattern from/to XML, which seems to work fine until now.
Just to be clear, I wasn't suggesting JSON as just a "file format"; I was suggesting using JSON strings internally to the program for all passing of configuration data between components.  This is vastly simpler than a massive LVOOP architecture.
Message 11 of 15
(1,153 Views)
Thank you for the clarification, I indeed thought you would only use it for saving and loading, not for communication between components. While it seems very elegant for the communication aspect, I wonder how you handle it inside your components.
Let us stay in the DQMH world. So we have our Module Data Type Def in the shift register of the MHL. I expect you hold your configuration data inside there too, don't you? In a big Cluster, in a Class, how?
Do you have read/writeSettingXyFromModuleData.vi with a TypeDef to use the setting inside the module?
And last but not least: How do parse the JSON to see which settings changed? I think this is the most important question, because we have to specifically react to some setting changes, don't we? So if I use JSON and a library, like "JSON Object Serialization v2.2.0.3 by G Craftsman" I just found on VIPM, I would only shift my problems into my modules, won't I?
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
Message 12 of 15
(1,144 Views)
There is a variety of options, but I often have a (non-type-def) cluster in a shift register called "Config" that holds the config info.  Then I just convert to/from JSON using standard JSONtext functions.   Example:
If I have Objects to save, then I need to have Get/Set JSON methods to do that, but internally these just use JSONtext subVIs in a similar way.  Then that JSON is combined with other config JSON, again using simple JSONtext functions.
Message 13 of 15
(1,136 Views)
Is there an advantage over Variant?
Message 14 of 15
(1,108 Views)
Variants just wrap existing LabVIEW datatypes, none of which are as easy to work with nested tree-like data as JSON.
Message 15 of 15
(1,087 Views)
