Sharing module templates / source code control
Hi All,
In a project where multiple developers are working together using github, I was wondering what the best way was to share a DQMH module template.
I didn't see an obvious way to do it using the DQMH template creation, since it relies on paths on your PC, though I'm sure I could have missed something.
Would it be better to use VIPM to create a package which installs the necessary files to the correct relative paths?
H
(1,078 Views)
Accepted by hutchforth
VIPM would be my recommendation.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(1,041 Views)
Thanks for the confirmation Sam!
(1,035 Views)
A more extended reply as to why is better to install your templates and other dependencies in vi.lib vs helping them local to your project:
https://www.hampel-soft.com/blog/hse-libs-go-vi-lib-enhancing-reusability-and-efficiency/
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(965 Views)
