DQMH Consortium Toolkits Discussions
Sharing module templates / source code control
Hi All,
In a project where multiple developers are working together using github, I was wondering what the best way was to share a DQMH module template.
I didn't see an obvious way to do it using the DQMH template creation, since it relies on paths on your PC, though I'm sure I could have missed something.
Would it be better to use VIPM to create a package which installs the necessary files to the correct relative paths?
H
(1,072 Views)
Accepted by topic author hutchforth
VIPM would be my recommendation.
Sam Taggart
CLA, CPI, CTD, LabVIEW Champion
DQMH Trusted Advisor
Read about my thoughts on Software Development at sasworkshops.com/blog
GCentral
(1,035 Views)
Thanks for the confirmation Sam!
(1,029 Views)
A more extended reply as to why is better to install your templates and other dependencies in vi.lib vs helping them local to your project:
https://www.hampel-soft.com/blog/hse-libs-go-vi-lib-enhancing-reusability-and-efficiency/
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(959 Views)
