DQMH Consortium Toolkits Discussions
When installing DQMH just for LV2020_64b I get a missing dependency error...
Hi this is something I just found, I wonder if it has happenede to anyone before?
With having only LV2020_64b installed on my PC, I was getting error when installing DQMH from VIPM,
It reported back that I was missing dqmh_scripter.... package dependency but couldn't find it either....
After a while I found that you need to have LV2020_32b installed to install DQMH for 32b
get that missing dependency and be able to install it on 64b.
Looks like this was happening. Issue solved after installing 32b and then 64b
CLA, CTA
(2,145 Views)
We recently created an Azure VM that has LabVIEW and TestStand 64-bit 2020 (no 32-bit versions installed), and we didn't have an issue with installing DQMH.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
(2,115 Views)
Hi LFBaute,
I had a similar problem when installing DQMH on LabVIEW 2020 64 bit - the main DQMH package installed OK but none of the dependencies were found.
I found that refreshing the list of packages manually in VIPM allowed it to find the decencies and install everything correctly.  It seems that they don't get updated correctly during the initial install for some reason.  I don't know if there's a similar problem for 32 bit LabVIEW 2020 or if this only affects the 64 bit version
Cheers
Brett
Senior Software Development Engineer
https://theLonelyAnt.com
https://GDevConANZ.org.au
(2,108 Views)
That can explain Chris not having any issues, thanks for commenting
Ill review following your steps, Brett
CLA, CTA
(2,102 Views)
The same for LV2019 32-bit. Refreshed the package and it seems to find the missing packages.
(1,851 Views)
