DQMH Consortium Toolkits Discussions
Anyone using DQMH on Linux desktop?
I'm using DQMH a lot on Windows and on NI Linux RT, I just wanted to know if anyone has been using it on Linux Desktop (ubuntu or other)?
Cheers
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,266 Views)
No,  I never did that.
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(2,251 Views)
I tryed, but i'm facing an issue. I can not launch the VIPM. It send me this code error "100, no such file or directory". I'm on opensuse trumbleweed as you need the last version of rpm to install labview.
It may be due to the fact that i'm on 64bit OS.
(2,063 Views)
Indeed getting VIPM 2017 to work on Linux (Ubuntu 20 for us) was a real battle!
At first we used WinSCP to just transfer from Windows host to Linux VM the content of user.lib and vi.lib, doing it this way makes it easy to set access rights to "user".
Event if you succeed in installing VIPM, you still have the major pain point of having to run it with sudo, and therefore then have to change the access rights for everything that you install.
You'll find here a detailed way that worked for us to install VIPM.
As for running our DQMH based project on Linux Ubuntu 20 and OpenSuse it works just fine. No nonsense!
Epictetus
Antoine Chalons
(2,050 Views)
Thank for your help !!!
I've finaly followed several forum topics that lead me to this page (here), where you can find dependecies to install. After installation, i openned a root terminal et it finally launch VIPM. It worked.
The problem now is when VIPM try to install DQMH. VIPM launch labview, but labview lead me to a window that ask me to register my version (whereas i already did it). At last i click on activated my product... and nothing happend. It look like it try to open a URL, so VIPM try to launch firefox but it does not apparear.
to be continued...
(2,027 Views)
