11-02-2024 03:03 PM - edited 11-02-2024 03:04 PM
Using VIPM, I have installed this toolkit extension (LV2023, DQMH 7.0 installed), but the MGI panel templates don't show up when attempting to create a new DQMH module. How can I validate if the templates were actually installed, and is there a way I can do this manually?
11-02-2024 03:23 PM
I see the module templates when I install the latest version of the MGI Panel Manager with DQMH:
You can verify they are installed by ensuring the following files exist on your system:
[LabVIEW Data]\DQMH Module Templates\MetaData\Cloneable Panel.xml
[LabVIEW Data]\DQMH Module Templates\MetaData\Singleton Panel.xml
[LabVIEW Data]\DQMH Module Templates\Source\MGI\Cloneable Panel\*
[LabVIEW Data]\DQMH Module Templates\Source\MGI\Singleton Panel\*
If you don't know where the LabVIEW Data folder is on your system, you can find out at Tools > Options > Paths > Default Data Directory.
Note that there were some issues with the MGI Panels not having been updated to be compatible with recent DQMH releases. I remember hearing there were some plans in the works to update them, but I don't know if that's happened yet. You may want to run the DQMH Validate Module tool on MGI Panel modules you create.
03-24-2025 12:23 PM - edited 03-24-2025 12:23 PM
What version of DQMH and MGI Panel Manager are you using?
I have:
DQMH v7.0.1.1316
MGI Panel Manager v1.0.1.4
I'm unable to see the Singleton and Cloneable Panel options when I try to create a new DQMH Module. I previously had this working but after getting a new PC and reinstalling LV 2020 and these packages I don't see this option anymore. Potentially something to do with MGI Panels not working with this version of DQMH as you mentioned?
03-24-2025 12:27 PM
Did you verify the files are present on disk at the locations I described above? Did you verify that the Tools > Options location for [LabVIEW Data] matches those paths?
03-24-2025 12:40 PM
I don't know why, but only once I post something do I almost always solve my problem. Almost always caused by my own stupidity. I had installed MGI Panel Manager via VIPM, but never actually installed MGI Panel Manager - DQMH Panels.
Thank you for your help! Checking those file locations made me realize nothing was there and that something was clearly missing.
