DQMH Consortium Toolkits Discussions
issue when create new module from custom template
@Olivier-JOURDAN wrote:
Do you mean that you have an issue with templates when the template is not in the project you want to add a new module to? That is the original issue this thread is about.
If so, can you please give us more information? What's the error you get when creating the new module, etc...
What I meant to say is that if I create my template elsewhere other than the project where I'm using it it's not a problem.
Also, the template I originally created had as part of it an lvlib that was an OOP instrument driver.  I don't know if that was part of the problem but wanted to add that little bit of info.
Message 11 of 11
(505 Views)
