DQMH Consortium Toolkits Discussions
(my) DQMH PPL and VILIB PPL best practices
Debugging: (depending on what you want to do)
Exclude dependent packed libraries: (Always enabled!)
Exclude dependent shared libraries: (Always disabled!)
Use Pre-/Post Build Actions to optimize your build
  • Remove all Breakpoints before you build
  • Check for misssing Items.
  • set conditional disabled symbols
DQMH Module's (generic):
- Move Tester inside of the Library
- Set main.vi public (easier to debug)
Call (non PPL) DQMH from PPL DQMH modules
  • The GUI is available as source code and will be compiled later as EXE
  • The GUI DQMH modules are not used as a PPL
  • The Module1 uses requests from the GUI / delivers data with broadcasts
Obtain Request Events.vi
For all GUI-DQMH modules "Obtain Broadcast Events.vi and Obtain Request Events.vi) must be extended. The VI searches via "VI server" the instance with the valid UserEvent registrations).
TestStand error / stop module integration:
- generate an additional vi to receive the desired events under TestStand (running in a TS-thread)
Add LVLIBP-search path to your Application.ini file (TestStand and normal applications)
  • viSearchPath="C:\xxx\Components\Libraries\*"
  • ShowLoadProgressDialog=False
Lessons learned:
  • Circular dependencies
    It's not possible to build PPL with circular dependency
  • Namespace
    Attention the namespace of a VI or control and typedef changes Typedef controls. The type definition inside and outside the Packed Library is not compatible.
    It can cause problems with queues and type casting for example!
  • Semaphores
    If Semaphores are used over the PPL border, an separate LabVIEW Semaphores PPL (wrapper) must be created. The problem lies again in the fact that a Semaphore is in the background a "Typedef Queue" which gets a new Type in the new Namespace of the PPL.
  • TestStand
    If PPL cannot be opened with the TestStand "Runtime Engine", it may be because the controls on the front panel are not Pubilc.
    (For libs and for DQMH modules).
  • Missing Items in Projects / lvlib
    Missing items result in partially not executable PPL (even text files and images)
  • After renaming the project, the PPL build specification must be recreated
  • Broken code within "disabled structures" may break the PPL!
  • Never, ever use Error Rings and XNodes!
Main Application settings
If you receive "Error 1003 occurred at File XXX.lvlib:Start Module.vi" you can try the following setting:
  • I do not recommend "Disconnect type definitions" for PPL's", but for application its worth a try! 😉
In case of strange crashes, recompile the PPL with the MGI Solution Explorer!
  • Consider build order!
  • opposite direction of the hierarchy
=> Still under construction... please wait for updates! 😉
Have FUN with PPL!
Claude
CLA / CTD
(6,704 Views)
Updated and extended...
CLA / CTD
(6,644 Views)
Updated (Pre-Postbuild / Application settings)
CLA / CTD
(6,601 Views)
Added Main application settings
CLA / CTD
(6,295 Views)
HI , THIS HELPS A LOT. THKS !
I GOT A QUESTION:
The picture is not clear enough.Could u show me where  i can find the vi(the valid UserEvent registrations)?
Thanks!
(5,276 Views)
These VIs are only needed if you mix PPL and non-PPL event/broadcast registrations of the same library.
1) Insert the Helper_BroadAndRequest.vim in the "Obtain Request Events.vi" and "Obtain Broadcast Events.vi" in the false case.
2) Make the Wrapper_Obtain Broadcast.vi and Wrapper_Obtain Request.vi static in Memory
=> Replace "Obtain Request events.vi "Obtain Broadcast Events.vi" in the Main.vi of your DQMH module
Well, it sound a littlebit complicated and strange. But something magical happens with these little VIs. Try it and let me know! 😉
=> These little changes allow you to register events of already started PPL modules in non PPL modules.
=> Hint: all Helper_xxx.vi can be stored outside of the DQMH module. The Wrapper_xxx.vi are members of the DQMH modules
Cheers and have fun
Claude
CLA / CTD
(5,266 Views)
added "Never, ever use Error Rings and XNodes!" because of the learnings from Darren Nattinger
=> Thanks for sharing!
https://www.youtube.com/watch?v=HKcEYkksW_o&ab_channel=GDevConNA
CLA / CTD
(4,489 Views)
