 Anton.S
			 on
		11-08-2016
		06:35 AM
			3 Comments (3 New)
			Anton.S
			 on
		11-08-2016
		06:35 AM
			3 Comments (3 New)
		Hi!
PCI Express bus became more and more popular.
PCIe has a new type of interrupts - MSI/MSI-X.
Today VISA driver is able to work only with old style interrupts (Legacy).
Let me explain the main difference:
Legacy interrupt mask intA/B/C/D signals (these signals was in PCI bus, but not exist in PCIe bus).
These signals (for PCIe actually packets with Message setA/B/C/D) are shared between all PCIe devices.
So VISA driver spend a lot of time when it looks who produced this interrupt.
MSI interrupt is actually a Memory Write packet to preallocated address.
In this case VISA should already know which device produced this interrupt.
Also MSI interrupt can contain different interrupt vectors inside of Memory Write packet. So it would be very helpful to get access to vector value too.
Requesting MSI/MSI-X interrupts support to VISA driver.
Thanks a lot!
