It gets a bit annoying that PXI1Slot2 is listed after PXI1Slot14 when doing an ascii sort. I (ok, admittedly, my coworker) proposes having naming conventions that will allow for a better ascii sort. For instance, PXI1Slot002 PXI1Slot014.
