Data Acquisition Idea Exchange
labviewman
Log output signals (including XNET CAN) with FlexLogger
Status: New
The current FlexLogger implementation requires you to connect DAQ output channels to input channels and an additional XNET port to log output CAN signals, which adds to the cost of the DAQ setup/limits the amount of DAQ/chassis.
1 Comment
AndreasStark
NI Employee (retired)
Is there any update on this? It's a quite needed feature to log what you output so you can relate i.e. digital output actions to system reactions logged on analog input channels. Use case would be toggling a valve in a gaseous system and observing how the pressure changes as a reaction to it.
I found this plugin, but it's quite cumbersome: https://github.com/ni/niflexlogger-plugins/tree/main/PDK%20plugins/Digital%20Output%20Handler
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
