Congratulations to the winners and finalists of the LabVIEW Tools Network Awards for 2016!
A product that leverages domain expertise to tackle a particular application space. Examples of applicaton spaces include condition monitoring, data acquisition, wireless test, and more.
GTT LTE RBS Toolkit by Gefle Testteknik
A product that enables the NI platform to connect with, communicate with or control third-party systems. Third-party systems include hardware, software, protocols, languages, and services.
BACnet Protocol for LabVIEW Toolkit by Ovak Technologies
A product that enables developers on the NI platform to enhance their efficiency and productivity through reusable code, editor extensions, or software management tools.
UI Controls Suites by RAFA Solutions
A free product that gives back to the NI community, empowering its members to advance their knowledge and expertise.
Delacor Queued Message Handler (DQMH) by Delacor
| Algorithms after Dijkstra and Kruskal for Big Data by Ovak Technologies | Shortest-Path and Minimum-Spanning Tree-Finding Algorithms | https://www.ni.com/en-us/shop/product/algorithms-after-dijkstra-and-kruskal-for-big-data-and-iot-too... |
| LossLess Coding Library by OLYMP Engineering | Lossless Signal Compression and Decompression | https://www.ni.com/en-us/shop/product/lossless-data-compression.html |
| Wezarp Lite | Control LabVIEW and LabWindows/CVI™ Applications Remotely | |
| Metrology Lab by RAFA Solutions | Academic Lab Software for NI ELVIS | https://www.ni.com/en-us/shop/product/metrology-laboratory-software.html |
| Finance OHLC Plot by Austin Consultants | An Efficient Tool to Visualize Financial Data | |
| BACnet/IP Protocol by Ovak Technologies | Communicate Between BACnet Devices and NI Hardware | https://www.ni.com/en-us/shop/product/bacnet-ip-protocol.html |
| git4G by DATA AHEAD GmbH | Integrate Git Control Management Into a LabVIEW Environment | https://www.ni.com/en-us/shop/product/git4g.html |
| Reflective Ethernet Custom Device by Dvel AB | Direct Target-to-Target Reflective Ethernet Communication | |
| VI Suggester by Austin Consultants | Doubles the Speed of Programming by Proposing the Next V | |
| LogBook Toolkit by Step Automation & Test | Trap, Store, and Display All Your Application Events | https://www.ni.com/en-us/shop/product/logbook-toolkit.html |
| LIA-SFP (Lock-In Amplifier Soft Front Panel) by Ngene | Convert FPGA-Based DAQ Into Multichannel Lock-In Amplifier | https://www.ni.com/en-us/shop/product/lock-in-amplifier-soft-front-panel.html |
| Python Integration Toolkit by Enthought | Seamlessly Extend Capabilities With the Power of Python | |
| Waveform Compression by ST Solutions | Waveform Compression | https://www.ni.com/en-us/shop/product/waveform-compression-toolkit.html |
| Colorful UI Controls Palette by Bitlis-MEN | Colorful UI Controls Palette for LabVIEW | https://www.ni.com/en-us/shop/product/colorful-ui-controls-palette.html |
| Ultra Light UI Controls Palette by Bitlis-MEN | Ultra Light UI Controls Palette for LabVIEW | https://www.ni.com/en-us/shop/product/ui-controls-palette.html |
| eHS – Power Electronics Simulation Tool for cRIO-9068 by OPAL-RT TECHNOLOGIES | Simulation on FPGA Made Easy | |
| eHS – Power Electronics Simulation Tool for cRIO-9039 by OPAL-RT TECHNOLOGIES | Simulation on FPGA Made Easy | |
| SVG Reader for LabVIEW by Ngene | Read SVG Vector Graphics in LabVIEW | https://www.ni.com/en-us/shop/product/svg-reader-for-labview.html |
| ClampOn CAN Monitor by ClampOn AS | Configure, Test, and Monitor Your CAN Network and Devices | https://www.ni.com/en/support/downloads/tools-network/download.clampon-can-monitor.html |
| DataGrid for LabVIEW by Mike King | An Easy-to-Use Data Grid Table Solution for LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.datagrid-for-labview.html |
| NIVision OpenCV Utilities | Quickly Integrate Open Source Vision Algorithms Into LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.vision-opencv-utilities.html |
| Phase Coherent Acquisition and Generation (PCAG) Toolkit by INSol | Multichannel Phase-Coherent Acquisition and Generation Kit | https://www.ni.com/en/support/downloads/tools-network/download.phase-coherent-acquisition-and-genera... |
| Claudie_XLSX by ATEsystem | Read and Write Microsoft Excel Files in LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.compact-library-and-universal-data-im... |
| ChipScopePro Break-Out-Box by B&A Engineering | Debug FPGA Code in Real Time | https://www.ni.com/en/support/downloads/tools-network/download.xilinx-chipscope-pro-debugging-break-... |
| Physics Lab Assistant by Doug Harper | Data Acquisition and Analysis for Physics Laboratories | https://www.ni.com/en/support/downloads/tools-network/download.physics-laboratory-assistant.html |
| Virtual Physics by Doug Harper | Numerically Integrate Differential Equations of Motion | https://www.ni.com/en/support/downloads/tools-network/download.virtual-physics.html |
| SoftMotion Drive Interface Plugin-In for ASD-A2-E by Delta Product Corp | SDI Plug-In for Delta ASDA Servo Drives | https://www.ni.com/en/support/downloads/tools-network/download.softmotion-drive-interface-plug-in-fo... |
| Distributed Control and Automation Framework by NI Systems Engineering | LabVIEW Application Framework for Embedded Control Systems | https://www.ni.com/en/support/downloads/tools-network/download.distributed-control-and-automation-fr... |
| GDrive for LabVIEW by National Instruments | Access Your Google Drive Items from LabVIEW | https://www.ni.com/en/support/downloads/tools-network/download.gdrive-for-labview.html |
| pdfLaTeX for LabVIEW by Kinga Kasiak | Export Data From LabVIEW to TeX File and Compile to PDF | https://www.ni.com/en/support/downloads/tools-network/download.pdflatex-for-labview.html |
| AVP254 - Automatic Verification Platform for Safety-Critical FPGA by Barco Silex | The Smart Solution for FPGA Physical Testing | https://www.ni.com/en/support/downloads/tools-network/download.avp254.html |
