NIWeek is just around the corner! It'll be another week of great sessions and opportunities. Here are some sessions you don't want to miss:
TS8166 - Do Real-Time Right with the NI Jitter Benchmarking Framework
Robert Des Rosier, Partner Program Engineer, National Instruments
Troy Troshynski, Vice-President, Avionics Interface Technologies
One of the most important -- and often challenging -- aspects of any real-time system is the characterization of jitter. In this session, learn how you can improve and document the performance of your real time system with the NI Jitter Benchmarking Framework for LabVIEW Real-Time. Using Avionics Interface Technologies as a case study, we will explore how this benchmarking helped them get an edge on their competition.
TS8526 - Introduction to LabVIEW Scripting
David Ladolcetta, Partner Program Engineer, National Instruments
Gain an introduction to programmatically creating, modifying, and inspecting G code. Familiarity with VI Server is recommended but not required.
TS8527: Hands-On: Build a VI Package with VI Package Manager
Stephen Roso, Partner Program Engineer, National Instruments
TS8528: Explore Tools to Customize LabVIEW
LabVIEW Tools Network Awards
