DigiMetrix
Equipment for using the DigiMetrix Library with KUKA
I'm trying to get every necessary part together to give DigiMetrix finally a try.
I've asked Beckhoff and KUKA for the right device to get the EtherCAT Master-Master Communication running but nobody really understood what I'm trying to do... 🙂
So far, I found the EtherCAT Bridge EL6692 and 6695 which seem to be appropriate.
Are there some experiences with these Bridges?
When it comes to NI, we have a cRIO 9024+FPGA, PXI-8106, PXI-7854R and PXI 7813R and i hope that’s enough.
I would really appreciate if somebody could confirm that one of those EtherCat Bridges are going to do the job with our FPGAs.
Did I miss anything important besides mxAutomation that might be expensive?
I really don’t want to order electronics that won’t fit.
Kind regards
Samuel
(11,100 Views)
Accepted by hlos
Hi Samuel,
- EL6992 is the right choice for this library. You don't have to program this device, you just need to configure it by importing device description files provided with the library
- cRIO 9024 supports NI EtherCAT communication driver, so it means it can be used for robot control
- mxAutomation is a MUST in this setup
In addition to EL6992 you need to have Beckhoff EK1100 Bus Coupler. This is the device where you install EL6992. Please take a look at paragraph 1.3 of the attached document.
-Nikita.
Did you know LabVIEW can control industrial robot arms? - www.digimetrix.com
(11,092 Views)
Thank you Nikita for your quick reply and for posting the manual!!
I guess you were talking about the EL6692? I couldn't find any EL6992.
(11,073 Views)
Yes, I meant EL6692
Thank you for the correction!
-Nikita
(11,062 Views)
