DigiMetrix
How can I monitor the current position & status of Denso using Labview
I know there are functions like "current position" and "get robot status", but how can I see the real-time position & status, while robot is moving.
I mean, not the status at one point, but the entire time.
Thanks!
by S
(11,403 Views)
in order to read continuously robot position and status when the arm is moving, you could use a motion command with NEXT option as following:
move_next
this VI will be executed immediately without waiting the motion complete. Then after it you could place a while loop with reading of position and status until motion complete.
This way is not properly a real-time position and status reading but is the simplest way to get these info during motion.
Concerning real-time motion, ImagingLab is working on a new feature available from DENSO.
Hope this helps.
Simone
(11,400 Views)
Do I use a while loop to include everything, (i.e from denso open all the way to denso close) ? And place the function which reading position before the loop?   Thanks!
(11,396 Views)
Accepted by ZSH2010
Like this:
example_code
(11,393 Views)
Thank you! you are a genius!
(11,390 Views)
