Digital I/O
10bit parallel port
I'm trying to read a 10bit parallel port with a NI-6251 board synchronizing the acquisition with an external clock.
If I try to read only 8bit with the following code, everything goes well:
    DIGIN_Task = New Task("")
    DIGIN_TaskReader = New DigitalMultiChannelReader(DIGIN_Task.Stream)
    DIGIN_Task.DIChannels.CreateChannel(NI6251_Dev & "/port0/line0:7", "SIGNAL_DIN", ChannelLineGrouping.OneChannelForEachLine)
    DIGIN_Task.Stream.Timeout = 20000
    DIGIN_Task.Timing.ConfigureSampleClock("/" & NI6251_Dev & "/" & CLOCK_GATED_OUT, clockFreqKHz * 1000, SampleClockActiveEdge.Falling, SampleQuantityMode.FiniteSamples, nPixels * nScanlines)
    DIGIN_Task.Stream.ReadAllAvailableSamples = True
    DIGIN_TaskReader.BeginReadMultiSamplePortByte(nPixels * nScanlines, AddressOf sampleDIGchReadEventHandler, Nothing)
    DIGIN_Task.Start()
How can I read all the 10 bits? I can't declare port0/line0:7 + port1/line0:1?
(4,461 Views)
As you can see from the specs, only 8 lines are clocked. The others are static/software timed. You would need a different device.
(4,453 Views)
You're right:    "PFI/Port 1/Port 2 Functionality: Static digital input, static digital output, timing input, timing output"
I could use NI-6534 instead of 6251, is it true?
(4,442 Views)
Accepted by D.Anto
I haven't used one but I think it should work.
(4,438 Views)
