Digital I/O
3.3V Digital I/O
Has anyone found a 3.3V Digital I/O board or product that has LabView (or CVI) drivers available?
(3,810 Views)
Most of National Instruments DAQ DIO devices support TTL/CMOS logic. This means that they recognize low as 0-0.8V and high as 2-5V. I would first look at the user manual for a specific device to make sure it will work for your application, because different device have different specs (www.ni.com/manuals). The one catch is that they output 2.4-5 volts on the digital outputs, but if this is a problem you could use a zener diode to clamp the voltage to 3.3V.
I hope this helps.
Joshua Prewitt
(3,810 Views)
Thanks Joshua
(3,810 Views)
Hi Joe,
Check out the new PXI 6551 and 6552 high speed digital boards from NI they should do this. Links below:-
http://sine.ni.com/apps/we/nioc.vp?cid=12428〈=US
http://sine.ni.com/apps/we/nioc.vp?cid=12423〈=US
Hope this helps,
Nick
(3,810 Views)
