Digital I/O
using 6534 card for 32bits data pattern generation, same data are acquired by another 6534 card. The last 32bits always get missing, any suggestion?
I am using a 6534 to generate the 32 bits pattern, the pattern data is read by another 6534 board. It is a finite pattern loop test. However, I found the last 32 bits data get missing every time whatever the buffer size is. Attached is the vi, any suggestion would be grateful.
(3,084 Views)
It looks like you took one of the continuous examples and tried to make it finite. I took a look at it and made the rest of the modifications to make it work. It seemed that you were setting several values that do not need to be set.
Take a look at it and see if this helps.
Joshua
(3,084 Views)
Dear Joshua,
It works!
Cheers! You are my star of today.
(3,084 Views)
