Digital I/O
6501 digital input levels
I am using 6501 port 1 to read digital logic of my circuit output.  In 6501  port pins  have +5V and 4.7K pull-up resistors. Up to what voltage on the port pin (configured as digital input), 6501 declare as LOW and  HIGH?. I read elsewhere that voltage between 0 to 0.8V will be  reported as logic 0 and voltage above 2V will be reported as  Logic high. Is this correct?
Leyo Joseph
(1,525 Views)
Accepted by LeyoJoseph
When in doubt, read the scpecifications: USB-6501 Specifications
After reading the specifications...Yes, that is correct.  Those are fairly standard voltages for TTL.
(1,519 Views)
Thanks.
One more question  on this, please. I think there is a way to change the +5V operation top +3.3V by setting some parameters of 6501. How to do this?
(1,485 Views)
As an input, it will accept 3.3V levels.  But as an output, it will use 5V levels.  You can use a level shifting circuit to change logic levels, for example a SN74LVCC4245APWR.
(1,483 Views)
