Digital I/O
The data sheet on the PXI-6509 is a bit vague: does the 6509 support individual pins to be tri-stated (Hi-Z)?
(4,761 Views)
Accepted by Ed.r
You can't tristate individual lines, instead, work with the ports as stated in the following article: Why Can't I Tristate My NI 6509 Digital Lines? I hope this helps Smiley Wink
Alejandro C. | National Instruments
(4,745 Views)
Thanks for that
(4,739 Views)
