04-01-2012 06:43 PM
The data sheet on the PXI-6509 is a bit vague: does the 6509 support individual pins to be tri-stated (Hi-Z)?
Solved! Go to Solution.
04-02-2012 02:49 PM
You can't tristate individual lines, instead, work with the ports as stated in the following article: Why Can't I Tristate My NI 6509 Digital Lines? I hope this helps ![]()
04-02-2012 05:16 PM
Thanks for that
