Digital I/O
6524 Digital I/O
I'm currently using NI-DAQ-6254 board. As i understand, it has 3 ports:
Port 0 (P0.<0..31>)
Port 1 (PFI.<0..15>)
Port 2 (PFI.<0..15>)
I'm able to use the Port 0 for Digital Read and write, but am not able to do the
same with Port 1 & Port 2.
According to he 6254 Spec, Port 1 & 2 can be used for Static Digital I/P and O/P.
Then, why am i not able to read digital data using Port 1/ Port 2??
I was trying to use an external clock as there is no onboard clock engine on this
board.
rkpat
(3,490 Views)
Your 6524 board can use the external clock for timed digital IO on Port 0 only. Ports 1 & 2 (as noted in the documentation) can only perform static digital IO. This means that Ports 1 & 2 only operate by software timed DIO updates. An example of one of these static Digital IO programs can be found in LabVIEW under Help >> Find Examples >> Hardware Input and Output >> DAQmx >> Digital Generation >> Write to Digital Port.vi
Sal
(3,477 Views)
