Digital I/O
6534 Continuous Burst Mode Output Example
Does anybody have a Laview example program for continuous burst mode output of a 6534 card?
Many thanks.
ZYuan
(3,356 Views)
ZYuan,
In LabVIEW, open the Example Finder (Help » Find Examples...), click on the Search tab, and search for "burst". "Burst" should then appear in the keyword box. Double-click on it and you should get two examples, Burst Mode Ouput and Burst Mode Input. These examples came up in both LabVIEW 6.1 and 7.0 with NI-DAQ 7.
Also, here are the links to a couple of burst mode LabVIEW examples on the website:
Simultaneous Pattern I/O or Burst Mode I/O Using One 653x Device
Continu
ous Digitial Input--Digital Data Logger
You may also want to search for more example code on NI's support website at http://www.ni.com/support.
I hope this helps you get started with your application, good luck!
RossC
(3,356 Views)
