Digital I/O
6534 installation
Hi all - Im trying to install a 6534 board . Weve down loaded the DAC drivers from the NI site and followed configuration using MAX . However after pressing the Test Resources button in MAX the device responds that the board does not respond to the base adress. Has anyone any tips on how to proceed ?
Im using W2000.
thanks dht
(3,339 Views)
Hi
I've got a couple of things for you to try:
Swap the card to the other PCI slots on the computer and see if the problem remains.
Install the driver on another computer and test whether the test panel works now.
If both these fail, you may have a faulty card, which will need repairing. Contact National Instruments directly, you will be taken through troubleshooting steps and if required advised about how to return the card for replacement or repair.
Regards
SimonS
(3,295 Views)
