Hey guys, I have one set of NI PXI Platform, the PXI chassis is PXIe-1082, and there're several cards inside it, such as PXIe-6570, PXIe-6368 and PXIe-4142. I have replaced my NI controller with Adlink' PXIe-3985, but self-test in Max has failed. When I run the examples, error occurs in "burst pattern.vi". Besides, when I new a pin map, I can't find the related modules.
All the other NI PXI hardware can communicate successfully with PXIe-3985, except for the 6570. The NI PXI controller also works well with 6570. Has anyone encountered this problem? It seems there's some incompatibility  between 6370 and 3985, such as SMBus communication.
The driver version is NI-Digital 18.0, both NI and Adlink controller run 64-bit Windows 7.
