Digital I/O
USB NI-8451
Hi
I got an old USB 8451 box where GND pins on the connector and USB connector GND is shorted.
I also got a brand new one where the two connections id isolated from each other.
Is the deferens because the first one is defect or has NI changed this over time?
I have search the HW manual, but it gave me no answer.
Thanks in advance
Bjarne
(1,488 Views)
Hi Bjarne,
Depending on the age of your old USB 8451, I think it would be hard to find the documentation about the GND pins being shorted or if the circuit has changed.
Is it affecting your measurements?
(1,427 Views)
Hi
Newest update.
I was a measurement error that lead to state the was no connection between IO_GND and USB_GND.
I found the error on the failing NI-8154. 5V was faulty so resistance between GND and 5V was ~1 ohm.
Regards Bjarne
(1,420 Views)
