Digital I/O
776832-01 68-pin Custom Cable Connector/Backshell Kit wire size
Does anyone know what wire size the 776832-01 68-pin Custom Cable Connector/Backshell Kit connector's solder cups accept?
I need to create a custom cable but can not use ribbon cable connectors to do it so this is a promising alternative.
Thanks for everyione's help.
Respectfully,
Richard A Cleaver
(6,566 Views)
Hi Richard,
I looked at the specs for the custom cable connector and the maximum wire size should be 20 AWG.
I hope this helps,
S_Hong
(6,545 Views)
Hi S_Hong,
Thanks for your help.  You have made my day.  I was hopeful it was at least 22 AWG but 20 AWG is even better.  The base connector only allowed certain sizes of 30 AWG ribbon calbe or some versions of 26 AWG that the IDC contacts would crimp to.
Respectfully,
Richard A Cleaver
(6,530 Views)
Do you have drawing of the pinout for the 68 pin connector, ie pin 1-34 top left to right, 35-68 bottom left to righ when looking at it? Any help would be greatly appreciated. Thanks, Don
(3,996 Views)
