Digital I/O
usb-8452
I have an ASIC that generates can be an I2C Master or Slave. I want to make it a Master and the USB 8452 and IC slave. I also want the 8452 act as a slave receiver for I2C data that it can receive and plot. What labview blocks would allow me to act as an I2C receiver?
(6,328 Views)
Hi as you can see in the readme: "New Feature: Added support for the NI USB-8452 to be used as an I2C slave device". I recommend installing the latest driver version, then, look at the NI Example Finder under Hardware Input and Output. There should be a folder called I2C and SPI » I2C Slave with examples. I hope this helps
Alejandro C. | National Instruments
(6,311 Views)
Have you plan to support the slave SPI configuration like other competitors that already do?
(6,203 Views)
