Digital I/O
9403 output current, 2mA if all output
What circuit am I supposed to be able to drive with a 9403 DIO card in an automated system if the maximum current I can source on a channel is 2 mA if all my channels are outputs?
The whole card can only output 64 mA total, so even if I only have 4 or 5 DO we're getting to the current level that won't drive many logic circuits in the systems I am used to working with.
I tried looking at possibly using reed relays and optoisolators to allow the low current output from the 9403 to turn on a higher current source, but 2 mA won't even drive the optos or reed relays I could find.
A little help would be appreciated.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(4,361 Views)
Well I found a commercial relay driver that would only require 1.95 mA to switch on a relay, takes 5V TTL inputs, 2 channels of control, 2 relays driven.
Coil Voltages for the output available in 5, 12, 24 V to drive the coil of your selected relay of choice.
(4,360 Views)
Hello Ryan,
I am glad to see that you have found an answer to your question.  Please let me know if the solution you have found is still unacceptable and I will do my best to help you find a more acceptable solution (either through a different cDAQ module, or a different relay driver).
Browning G
FlexRIO R&D
(4,341 Views)
Thanks for the offer of help.
No other cDAQ module will work as far as I can tell to get the channel count in the cRIO system.
(4,335 Views)
Hi Rvallieu,
I am facing the same issue with the NI9403.
Could you share the brand and type of these relay's?
It would help me a lot.
Thanks in advance!
(2,960 Views)
