12-22-2009 08:09 AM
I am a rokkie Labview SignalExpress User. I would like to generate digital outputs but when I try it with N samples or continious samples it does not work, it gives error which is
Error -200077 occurred at DAQ Assistant
Possible Reason(s):
Measurements: Requested value is not a supported value for this property.
Property: SampTimingType
You Have Requested: Sample Clock
You Can Select: On Demand
Although I can generate one sample so could you please help me about this problem?
ERS
Solved! Go to Solution.
12-22-2009
08:40 AM
- last edited on
03-18-2025
03:26 PM
by
Content Cleaner
Per the USB-6009 Manual, this device does not support timed output. The best you can do is generate one sample of your waveform at a time.
12-22-2009 03:14 PM
One sample is enough for my destination, I can generate N samples or continuous samples with analog output, however I need digital output.
Actually, I will send digital outputs to motor and one sample is only one step for motor. I need 150 steps or more.
Is there any alternative for it? Please help me..
Thank you,
ERS
12-23-2009
09:22 AM
- last edited on
03-18-2025
03:26 PM
by
Content Cleaner
Using the USB-6009, the best you'll be able to do is update the output in a loop as fast as possible. If you can upgrade hardware, the counters on the USB-6211 are able to generate pulse trains and can do timed DIO.
12-23-2009 12:42 PM
How can I update the output in a loop as fast as possible, I mean with which parameters?
I seen that somebody used sweep mode for that kind of problem. However I do not know how to apply this function. What do you think does it work with sweep function?
We have USB- 6229 as well, I will try with that as soon as possible however other students are also using it so if I could do that with 6009 it would be better.
Thank you,
ERS
01-04-2010 03:00 PM
Hi!,
Could you please tell me about why there is no problem when I want to generate analog inputs, however when I try to generate digital inputs it gives error (Error -200077) as I introduced on the top with daq ni 6009?
Please I need your help,
Thank you,
ERS
01-04-2010 03:33 PM
01-04-2010 03:57 PM
As mentioned before, the USB-6009 does not support clocked digital output. "N Samples" and "Continuous" generation modes are only available for devices that are able to use an onboard clock to generate samples. Analog input on the USB-6009 uses can use an onboard clock, and thus can use the "N Samples" and "Continuous" modes. The best you'll be able to do with the USB-6009 is to toggle the value on and of with software timing. One way would be to use a DAQmx Generate step to set the value high, an execution step to enable hardware reuse, then another DAQmx generate step to set the line low. Run this in a loop and you'll get something of a digital pulse train (though it won't be terribly pretty.) It will be pretty slow and very nondeterministic. This means that some iterations may only take a few milliseconds, while others may take a lot longer.
07-24-2018 07:54 AM
It may be helpful if you included a brief VI to the solution you proposed for early Labview users like myself
