Digital I/O
9477 update rate
I have a cDAQ 8184 chassis with a 9477 sinking DO module. In the specification stands: Update Rate = 8µs.
Now my question, what does it mean? I have to switch die outputs in a resolution of 1ms, but the fastest way currently is around 50ms !
I create a DO task for one channel, and toggle it in a while loop without any delay, calling the DAQmx Write (Digital Bool 1Line 1Point).vi. I can't get it faster as 50ms.
Is the update rate of 8µs relevant only with usage of a cRIO chassis?
(4,966 Views)
Accepted by Madottati
I don't know if your hardware supports hardware timed single output. If it does, you have to program it. Of it doesn't, then with your 1 point timing, you are using software timing. You would need to use the n sample write and specify the clock.
(4,957 Views)
