Digital I/O
9477 usage for 10 Amp motor
Hi all,
can i use 9477 , by making 10 channels in parallel and connecting to a motor that draws 10 Amp, 12vdc, i have an external supply voltage (tenergy battery pack 12Vdc, 10,000 mAh, i am connecting 3 battery packs in parallel to make 30,000 mAh ) that will give power to motors Vsup,  this will also supply the compactRIO also that holds the 9477 digital out sinking module.
is this scheme ok without damaging the CRIO and modules
plz help
Thanks in advance
(3,602 Views)
Hi there,
Basically, you just need to make sure that the 9477 does not draw more than .625 A per channel. As far as the cRIO, which model are you planning to use? If this is the 9074, then you will find the power requirements on page 22 of the manual found on this link:
https://www.ni.com/docs/en-US/bundle/crio-9072-9073-9074-seri/resource/374639f.pdf
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(3,590 Views)
