Digital I/O
Screlock size for NI 6534 68 way connector
I am using an NI 183432B-01 shielded cable that connects a 6534 digital I/O card to a CPLD card on an instrumentation rack. The cable has 2 male screwlocks on each end, similar to standard PC monitor cables. The male connector on the 6534 card has 2 female screwlocks. The connector on the CPLD card doesnt. I need to add those screwlocks to the CPLD card to support the heavy cable.
I am wondering what is the size of the threads (internal and external) of the female screwlocks that are compatible with the 183432B-01 cable.
Alex
(3,913 Views)
Hey Alex,
Is this what you are looking for?
KB: Specifications and Dimensions of Jacksocket Screws Used on 68-Pin Board-Mount Connectors
Product Page: Jacksocket Screw Set for 68-Pin Board-Mount Connectors
Retrofitting Your PCI/PXI DAQ Device or Accessory
And here is a link to some PCB Mounting Connectors if you don't already have one on your CPLD board.
Hope this helps. Let us know if this is not what you are looking for. Thanks, and have a great day.
DJ L.
(3,909 Views)
That is exactly what I was looking for. The additional information is also much appreciated. Thanks DJ L!
(3,889 Views)
