Digital I/O
About DIO24 PCI digital card question
Hi
I have one DIO24 PCI digital card using for data acquisition in windows 2000, I already wrote a driver for the windows 2000, Now I have a data source sample rate at 8k, when I collected the data, but I losed some words, I want to know whether it can handle 8k data sample rate. thanks
sam
(3,312 Views)
Sam,
The transfer rate of the NI PC-DIO-24 card is dependant on a variety of factors. According to the documentation the maximum transfer rate is 50 kbytes/s with a constant sustainable rate of 1 to 10 kbytes/s (using NI-DAQ software). Some influential factors include computer system performance, programming environment, execution mode, and the presence of other processes running concurrently on the system. (see NI PC-DIO-24 User Manual)
I would recommend using NI-DAQ if you are not already doing so. The NI-DAQ drivers are free on our website and can be downloaded at NI-DAQ 7.1 for Windows 2000
The following also may prove helpful:
NI PC-DIO-24 Spec Sheet
If none of this helps you out please post again with more details of what you are trying to do and I�ll be glad to help out in any way I can. Good luck!
Craig H.
NI Applications Engineer
(3,311 Views)
