Digital I/O
Need realtime controls of PCI-6503 at ~5kHz
What options do I have to attempt to use the PCI-6503 (PCIDIO24) to do simple digital communications at around 5khz?
(3,172 Views)
Here is link to the specs document on the PCI-6503:
PCI 6503 Specs
With this board software timing is your only option. If you need hardware timing for your digital communications look to the NI-653x series:
NI 653x Specs
If you have any other questions please post them. Hope that helped!
Craig H.
(3,172 Views)
