When you say that you installed the RTE, did you install the LabVIEW RTE or the CVI RTE? The AccessHW library requires the CVI RTE. If you installed the CVI one, you might try a more recent version, the CVI RTE is always backwards compatible, so the CVI 7 RTE should run any CVI program.
Ryan K.
