Digital I/O
Acq&Graph Voltage-Int Clk.vi error-2147220712
Hi All,
I had this Acq&Graph Voltage-Int Clk.vi running excellently since 4yrs. Only yesterday I see this error poping when I run this program.
The pop up says : Error-2147220712 occured at DAQmx Create channel (AI-Voltage-Basic).vi
I tried to run the example Acq&Graph Voltage-Int Clk.vi and I get the same error.
Tried to repair the DAQmx: controlpanel >>> Add remove prog >>> NI software. Inserted the Disc DAQ 7.4 and I did run the repair. Even after this the error is not resolved.
could you help me to resolve this. Thanks a lot.
Regards
Nag
Message 1 of 1
(4,468 Views)
