Digital I/O
Acquiring a 1Mega Hz signal Using USB6009
Hi there,
I am new to Labview and i am trying to acquire a 1Mhz analog sine wave through USB6009 from a circuit board and evalute the spectrum of the signal.
I have created a DAQ and it says that the maximum rate at which i can acquire a signal is only 48K3 and i am gettting an error if i try to increase the rate.I would be very thankful if you could tell me how to overcome this problem and acquire signals in Mega Hz range.
Thanks and Regards,
Jayanth
(3,506 Views)
The product page for the USB 6009 makes very clear that the max sample rate is 48K/sec.
(3,501 Views)
