Digital I/O
Binomial random numbers as digital outputs
Greetings.
I am using a PCI 6259 card with LabView 8. I would like to drive 8 solenoids such that the probability that any one solenoid is activated at each time step ( variable 10/20/50/100 ms) is the result of a binomial trial. So, at time step n (0<=n<=N, a large number), I would like to generate coin tosses and take the 1's and 0's to drive the solenoids. I have written some code to do this, however DAQmx generates an error saying the following:
Error -200565 occurred at DAQmx Write (Digital 2D U8 NChan NSamp).vi:1
Possible reason(s):
Specified digital channel contains more bits than supported by the 8-bit version of DAQmx Port Write.
Use the version of DAQmx Port Write that supports wider digital ports.
Minimum Write Size (In Bits): 32
I am attaching my code here. Kindly suggest the problems or alternatives to this code for runnin this task.
Aniket
(3,701 Views)
Hi Aniket,
I ran your code as-is with both an actual PCI-6251 and a simulated PCI-6259, and I did not receive the error in either case.  Are you changing the default values of any of the controls before running the VI?
Andrew W
(3,690 Views)
Yes, with the default setting on, it does execute without error. But if you change the waveform length, which I think should change the number of samples written to the task, the code runs into errors.
(3,677 Views)
Also, if I do not change that parameter, there is no output at all. And with it changed, the VI shows errors.
(3,677 Views)
I think there were just some problems in how you were building the waveform array.  Take a look at the modified VI and let me know if this works for you.
Andrew
(3,669 Views)
