Digital I/O
Acquiring digital temperature signal with USB-6211
Dear NI-fellows,
I own a USB-6211 DAQ-Module and I am planning to connect a digital temperature sensor, just to get accustomed to digital I/O. So I found the:
Iduino DS18B20 sensor (SE029), which should fit to the task.
Will my NI device support this kind of digital input signal?
Thank you very much
Lysandros
(3,021 Views)
Hi Lysandros,
the USB-6211 is using TTL logic as you can see in the spec. If your sensor supports that, it will work. You should find that information in the specification of your sensor.
My guess is yes.
Cheers,
Ramona
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,995 Views)
